Should I be worried?
Old Mar 27, 2008 | 10:34 PM
djmagic's Avatar
djmagic
Default Should I be worried?
Well i was driving my car today, well i slowed at a light to make a left turn, complete stop. Well i tap the gas and the car stalled and the oil light came on. It started backup no problem. Also every now and then it starts rough, like two tries. Battery is fairly new. My car is auto and about68k on it.
Old Mar 27, 2008 | 10:46 PM
mjj1587's Avatar
mjj1587
Default RE: Should I be worried?
maybe oil pump? is the car still under warranty?
Old Mar 27, 2008 | 10:57 PM
djmagic's Avatar
djmagic
no i wish, i bought it private party also so no. Unless it had a 7/70 warranty, no.
Old Mar 27, 2008 | 11:29 PM
Mat00ES's Avatar
Mat00ES
Do the on/off code check. I've noticed my car will have codes, but not trip the CEL.
Mat
Old Mar 28, 2008 | 12:23 AM
Baddog44's Avatar
Baddog44
ORIGINAL: djmagic
if yer not low on oil which im sure u have already checked lol then its prolly oil pump
Old Mar 28, 2008 | 12:33 AM
djmagic's Avatar
djmagic
okay to check for codes how do you do it? The oil was a little bit over
Old Mar 28, 2008 | 12:41 AM
Mat00ES's Avatar
Mat00ES
Turn the car on and off three times, don't start it. Then, if any, the codes should pop up on the odometer.
Mat
Old Mar 28, 2008 | 02:20 AM
djmagic's Avatar
djmagic
ok so it just said done. So i'm guessing no codes so i guess that is a good sign
Old Mar 28, 2008 | 11:12 AM
NeonOn19s's Avatar
NeonOn19s
when you did your audio... did you replace your terminals on ur battery... I had the same problem with mine, and the main cable to the fused shorted. I replaced it and everyting went back to normal....
Old Mar 28, 2008 | 12:38 PM
djmagic's Avatar
djmagic
i'm not sure if they did or not. I'm hoping it doesn't happen again. If it does i'll keep you all updated. My dad says he wants to compression test it on wedsnday.
