ideas
Old Mar 29, 2008 | 10:43 AM
cyrus07gup's Avatar
cyrus07gup
Default RE: ideas
what mods r needed 2 get the hp i want besides the turbo???
Old Mar 29, 2008 | 10:58 AM
GrApHite03's Avatar
GrApHite03
Default RE: ideas
ORIGINAL: cyrus07gup
to get to close to 400 hp, be prepared to fork over about $5000-$7000 in parts...
bone33's Avatar
bone33
Default RE: ideas
tell ya what Mr. Pushy, why dont ya read on the forum....... we have been discussing this issue for years, and get back to us. or you could ask your dad, the mechanic.
Old Mar 29, 2008 | 11:02 AM
GrApHite03's Avatar
GrApHite03
Default RE: ideas
Here is a mod list from a 400hp 2.0l
Engine Modifications:
Bottom: [ul][*]Wiseco 8.1:1 .020 over Forged Turbo Pistons[*]Crower Connecting Rods[*]ARP Rod Bolts[*]Clevite Rod Bearings[*]Clevite Main Bearings[*]Wiseco Piston Rings[*]Fully Balanced[*]Blueprinted[*]ARP Main Studs[*]Heat Treated Crank[/ul] Top: [ul][*]DCR Port and Polish Cylinder Head[*]Crane Cams #22 / #18[*]Fidanza Cam Gears[*]Crane Valve Springs[*]Crane Titanium Retainers[*]REV SS Valves +1mm with backcut[*]3-Angle Valve Job[/ul] Other: [ul][*]Ported Intake Manifold[*]Intake Manifold Spacer[*]Upgraded Throttlebody[*]Throttlebody Spacer[*]Upgraded Motor Mounts[*]Polished Valve Cover[*]Magnecore Sparkplug Wires[*]NGK Spark Plugs [/ul] Turbo Modifications:
[ul][*]AMS GT37R Turbo[*]AMS Tubular Manifold[*]Tial 38mm External Wastegate[*]HKS Super Seq Blow Off Valve[*]AGP Race Intercooler[*]AMS Hotpipe Piping[*]Exhaust Depot Piping?[*]Needswings 3in Downpipe[*]McCord 3" Electronic Cutout[*]Greddy Profec B SpecII Boost Controller[*]HKS Type 1 Turbo Timer[/ul]
Fuel Modifications:
[ul][*]AEM Engine Management System[*]1000cc Fuel Injectors[*]Aeromotive Fuel Pressure Regulator[*]Aeroquip SS Lines and Fittings[*]Polished Fuel Rail[*]Walbro Fuel Pump[*]Bosch Inline Fuel Pump[*]Aeromotive Fuel Filter[/ul] Drivetrain Modifications:
[ul][*]Dual Disc Clutch[*]Factory Quaife LSD[*]Booger Shifter Bushings[/ul] Interior Modifications:
[ul][*]Mopar Short Throw Shifter[*]Modified Cluster/HVAC for Blue Lighting[/ul] Rubber/Suspension Modifications:
[ul][*]MSR 116 17"x7 Rims[*]245/40/17 Tires[*]Image Perf 32way adj Coilovers[*]Front Strut Bar[*]Rear Strut Bar[*]Hotchkis Front Sway Bar[*]Hotchkis Rear Sway Bar[*]Suspension Bushings[/ul]
hope you got deep pockets...
Old Mar 29, 2008 | 11:23 AM
bone33's Avatar
bone33
Default RE: ideas
good answer graphite.
Old Mar 29, 2008 | 11:29 AM
cyrus07gup's Avatar
cyrus07gup
Default RE: ideas
thanx thas all i needed to no... pics of before and after coming soon...not pushy just interested in doing what i need to do to get the info i need...
Old Mar 29, 2008 | 11:48 AM
bone33's Avatar
bone33
Default RE: ideas
this guy has 220WHP and did all that stuff listed.... so to get 400HP, your gonna have alot more to do. https://dodgeforum.com/m_1245877/tm.htm
Old Mar 29, 2008 | 03:32 PM
MJND1990's Avatar
MJND1990
Default RE: ideas
Srt-4 swap for $5500 and a Mopar stage 3 for around $1800. That will be good for 320hp on regular gas, 375hp on race fuel.
