MFS wires
Old Apr 2, 2008 | 03:38 PM
Baddog44's Avatar
Baddog44
Default RE: MFS wires
ORIGINAL: Baddog44
hold on let me see if i can pull something up....low beams are gonna be pin #16 and i think it is violet with a white strip let me check fogs
Ok fogs are pin #14 its pink with a light green stripe on it or its light blue one or the other
i dont know what yer switch will look like but if it requires a ground just connect a wire from the ground of the switch to an actual ground...the wire yer taking from yer multifunction switch is your power wire and that should be all u need for yer switch....
EDIT: the foglight wire in pin #14 is in fact pink with a light green stripe fyi
