ignition harness
Old Apr 2, 2008 | 12:56 AM
luke9511's Avatar
luke9511
Default ignition harness
hello everyone im new to the forum and i own a 2003 dodge neon sxt and i am wanting to hook up a remote starter but im having trouble locating the ignition harness, can anyone tell me where to look? thanks in advance for any help/advice
Old Apr 2, 2008 | 01:44 AM
contagious19's Avatar
contagious19
Default RE: ignition harness
by ignition harness do u mean da wires dat lead to the ignition coil?
Old Apr 2, 2008 | 01:55 AM
Caraudioholic24's Avatar
Caraudioholic24
No i think he means the main ignition harness from the key cylinder. Take down the knee bolster and follow the wires from the key cylinder. I've been in the car audio business for 14+ years. I can get you the wiring schematics from DEI if you need them.
Wait till everyone sees the trunk layout I have in store. If you need anything else pm me.
Old Apr 2, 2008 | 02:01 AM
djmagic's Avatar
djmagic
caraudio, i want to see some pics of your stereo. Yea i think it is underneath the steering wheel area
Old Apr 2, 2008 | 02:15 AM
contagious19
i want to get a cleaner setup on mine. i want to go all kicker, like kicker amp for my 12cvrs. im goin to get my trunk fiberglassed and have 3 subs
Old Apr 2, 2008 | 08:24 AM
luke9511's Avatar
luke9511
ORIGINAL: Caraudioholic24
yes thats it im trying to install remote starter but cant find the ignition,accessorywire and starter wire
Old Apr 2, 2008 | 09:08 PM
luke9511's Avatar
luke9511
the knee bolster is the plastic thing right below the steeringwheel colum cover correct? if so thats where i have been looking and have only found one thing of wires and im supposed to be getting like 12 volts from certain wires in certain postions and nothing from others in certain postions, but yet i have only found one blue wire which gives me 12+ volts in the start postion
Old Apr 3, 2008 | 01:33 AM
Caraudioholic24
weird start is yellow If I remember. What kind of tool you using to test the wires. PM your email and I will send you a copy of the wiring diagram. They charge me to get this info but I think you had enough headache for right now. You are following the ignition harness and not the harness going to the headlight switch and stuff right. And yes the knee bolster is the plastic piece under the steering wheel
Old Apr 3, 2008 | 02:50 AM
luke9511's Avatar
luke9511
no its not the one for the headlight switch, today is my day off so i will take some pics for ya and show you and im using a voltage meter to test the voltage, the the light version also im going by the wire diagram here http://www.the12volt.com/installbay/forum_posts.asp~TID~11309
Old Apr 3, 2008 | 05:22 AM
Sawhiskey's Avatar
Sawhiskey
ORIGINAL: contagious19
Kickers are the best subs out there. I had 10" Kicker L5's for over 2 years no problems at all. They are the best subs to go with most definetly. Next time you get subs get the solo barics, square subs ftw! Ill never buy anything other then a solo baric again.
