rims
Old Apr 8, 2008 | 10:58 PM
capo180's Avatar
capo180
Junior Member
Default rims
Whats the biggest rims that you can put on a neon with out giving up alot of driving quality and feeling every single bump??
Old Apr 8, 2008 | 11:24 PM
djmagic's Avatar
djmagic
Default RE: rims
17-18's
Old Apr 9, 2008 | 01:27 AM
Izero's Avatar
Izero
Default RE: rims
18's aren't suggested but they are the max size you can put on without problems....
Old Apr 9, 2008 | 01:30 AM
contagious19's Avatar
contagious19
Default RE: rims
or u can put on some 20's
Old Apr 9, 2008 | 09:33 AM
SiX1N9N3's Avatar
SiX1N9N3
Default RE: rims
17's and 18's are fine any bigger would emphasize the rims way to much unless u have good all around mods to the body like some people do on this site.. especially neonon19's(sorry if i spelled it wrong)he has a sweet looking ride and he's still modding it out..
Old Apr 9, 2008 | 09:37 AM
ricerchik02's Avatar
ricerchik02
Default RE: rims
I have 18's and the ride quality is slightly compromised.
It's no biggie tho.
Old Apr 9, 2008 | 10:41 AM
NeonOn19s's Avatar
NeonOn19s
Default RE: rims
ORIGINAL: SiX1N9N3
Thanks!!!
The ride isn't that bad, if you have a good suspension set up 19's = air suspension or coilovers... 17-18's can be done with lowering springs.... BTW even with the 19's and a good suspension you need to modify the fender wells (trimmed / rolled) 19x7.5 are a good setup with minimal modifications.... Now i'm at 19x8 and can't even drive right now w/o damaging my paint and tires... its a rubbin...... need to roll some more...
On a second note...
I think that the largest I have seen on a neon is 21"... but if i'm correct he/she did the suspension lift to make them fit...
Old Apr 9, 2008 | 11:04 AM
Caraudioholic24's Avatar
Caraudioholic24
Default RE: rims
yea for ride quality I would say 17's. 18's use a 35 series tire which is a rubber band. 17's use 40 series and are thin but not as bad. if you get a decent lip on a 17 from a distance it will look like an 18.
Old Apr 9, 2008 | 02:03 PM
NeonOn19s's Avatar
NeonOn19s
Default RE: rims
true....
Old Apr 9, 2008 | 10:01 PM
capo180's Avatar
capo180
Junior Member
Default RE: rims
okay thanks guys
