View Poll Results: A poll
Voters: 23. You may not vote on this poll
what color calipers do i go with????
RE: what color calipers do i go with????
i am pulling the caliper off and painting it, prolly sand blasting them and painting them that way..... but if u dont have time to pull them off, u can paint them on the car.... just unbolt the caliper from the spindle and sand them down good and then paint them......
I would go with either a gloss black or the electric blue...no on the silver though.
You know that's pointless right...?
Sand them down, put on a base coat of primer if you want, but not necessary (i didn't, and mine still look "ok" after two years). You can use either high temp engine enamel (my choice), or the Duplicolor "Caliper Paint" (which is basically high temp engine enamel anyways [8D]). Make sure you use several light coats and you can finish off with a high temp top coat to help protect the paint and keep it shiny-ish.
Also, you can either take the calipers completely off the car, or just unbolt them from the knuckle (then wrap an old towel around the rotor/knuckle to prevent overspray) to protect the rotor and give better flexibility for painting, or just leave them on totally and just make sure you tape off the rotor and dont overspray. I went with option two because it was the easiest and most practical...
ORIGINAL: Izero
i wanna paint my rotors too but idk what color to paint them (( im thinking mebbe silver but idk!? ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
ORIGINAL: Sawhiskey
While this is here. Any tips on painting them, any pics of what shold be covered. Im painting mine soon I need some pointers thanks.
kinda off topic, butmyneons engine HAS BEEN STOLEN!!!!!!!!!!
just kidding just got it pulled out of the engine bay, and lots of things r running threw my head on what i am going to do with it. lots of welding, and lots and lots of cleaning things up..... i will take a few pics tomorrow and a few things that i plan to do......
