P1684
Old Apr 22, 2008 | 05:49 AM
za bushie's Avatar
za bushie
Default P1684
Hi
I have the following problem:
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
How do i fix it.
any help please
Thanks
jose
2002 2l automatic neon
Old Apr 22, 2008 | 06:19 AM
SiX1N9N3's Avatar
SiX1N9N3
Default RE: P1684
get a new sensor
Old Apr 22, 2008 | 09:32 AM
djmagic's Avatar
djmagic
Default RE: P1684
i think it just means the battery was disconnected within the past 50 starts
Old Apr 22, 2008 | 07:11 PM
03neonRT's Avatar
03neonRT
Default RE: P1684
ORIGINAL: djmagic
Bingo.
https://dodgeforum.com/m_1277575/tm.htm
Old Apr 25, 2008 | 07:11 AM
za bushie's Avatar
za bushie
Default RE: P1684
thanks for the reply. i also have the following code P1687 Metering Oil Pump Stepping Motor Circuit Malfunction (not sure what this code means) I recently had my timming belt changed so perhaps something was not refitted or damaged during the process. as a matter of interrest how does onereset yourPCM?
Old Apr 25, 2008 | 12:34 PM
djmagic's Avatar
djmagic
Default RE: P1684
disconnect the negative cable, leave it off for a little bit. But zabushie, don't worry bout the 1684, it should go away, if you disconnect it will still be there.
Old Apr 25, 2008 | 12:47 PM
Izero's Avatar
Izero
Default RE: P1684
why would he disconnect the neg. cable.... if he does that he will run the risk of shorting some of the cars electrical systems out wont he...? i thought the negative terminal acted as a ground...? but hey w/e good luck
Old Apr 25, 2008 | 01:20 PM
djmagic's Avatar
djmagic
Default RE: P1684
i disconnected my negative terminal, i think the ground it the positive. But he doesn't have to disconnect the battery, the code should go away by himself
Old Apr 29, 2008 | 06:16 AM
za bushie's Avatar
za bushie
Default RE: P1684
Thanks. how does one reset the PCM
