i need help!!!
Old Apr 24, 2008 | 03:00 PM
a_aguilar_jr82's Avatar
a_aguilar_jr82
Default i need help!!!
the air bag light goes off, the anti thief light, the oil light, my gauges go up and down.. and i have no idea what to do... AUTOZONE cant help told me to call dealer.. and dealer wont help with out me taking it in... the car drives fine, its just the cluster going crazy... ne ideas on how to fix this without having to take out a loan to pay for the repairs???
Old May 8, 2008 | 11:06 AM
inthewerks's Avatar
inthewerks
Default RE: i need help!!!
if the car drives okay, than its not a sensor or ecu problem. you might be getting electronic interference somewhere around your cluster that causes it to act crazy. anything you installed recently close to the cluster? also could just be some loose connections where the cluster plugs in at. hope this helps.
Old May 24, 2008 | 07:51 PM
mjs182004's Avatar
mjs182004
my 02 did the same thing, i took it to the dealer and it took them like a week to figure it out. its the actual intrument panel that was bad. itd not cheap either, around 5 - 600 dollars
[align=left] [/align]
Old May 24, 2008 | 09:54 PM
Baddog44's Avatar
Baddog44
um just a thought... u might wanna check your terminals on yer battery....make sure the terminals arent corroded or anything if they are just get some baking sodea and a wire brush and clean it. This happened to a buddy of mine to his grand cherakee and he called me up and foudn his negative terminal just hooked up with corrosion lol his gauges were flying everywhere as well
