CLUSTER SWAPS
Old Apr 25, 2008 | 07:45 PM
jenneyandmatt1327's Avatar
jenneyandmatt1327
Default CLUSTER SWAPS
What can you swap around and what does it take to work (reprogram) ? I,m buying a 04 base model neon and i have a 04 donor car with the white faced gauges and a tach (SXT). THANKS FOR ANY HELP YOU CAN GIVE ME !!!
Old Apr 25, 2008 | 08:07 PM
neon03se's Avatar
neon03se
Default RE: CLUSTER SWAPS
you don't need to do anything to program it. It's plug and play, it won't display your actual mileage though, it will dispay whatever mileage the car it came from had.
Old Apr 25, 2008 | 11:35 PM
jenneyandmatt1327
THANKS for the response !!! I had asked because i looked at other posts and they where talking about security and different color keys . THANKS AGAIN MATT !!!
Old Apr 26, 2008 | 02:01 PM
03neonRT's Avatar
03neonRT
The security thing is in regards to the sentry system, which if the cluster came out of a sentry enabled vehicle and your car doesn't have sentry, then a little light on the cluster will show up because the cluster isn't receiving a signal from the sentry system. It wont affect starting or anything, but you may want to take the LED out if it annoys you too much.
