couldnt find a answer...
Old Apr 26, 2008 | 05:31 PM
superdan's Avatar
superdan
Default couldnt find a answer...
i searched the forum but could not find the answer for why my car idles at 3500 rpm after start up...when i shut it off then back on it idles at 1000...thanks in advance
Old Apr 26, 2008 | 05:34 PM
Adionik's Avatar
Adionik
Default RE: couldnt find a answer...
It shouldn't idle that high. It should "maybe" reach that high when you first turn it on but even that's really high.
Your IAC or TPS might be going out
Old Apr 26, 2008 | 06:02 PM
superdan's Avatar
superdan
yeah and i also forgot to mention it sounds like its revving...keep in mind im not moving or in gear...lol but thanks adionik i will check that out...
Old Apr 26, 2008 | 06:26 PM
Adionik's Avatar
Adionik
You probably have a vac leak as well...if the cars starts revving on it's own it's usually that. Check around the throttle body for all those little hoses and the PCV valve
