Mopar side skirts??
Old Apr 28, 2008 | 06:00 PM
2003SXTneon's Avatar
2003SXTneon
Default Mopar side skirts??
I just got my side skirts any tips/suggestions?
They look tricky to put on, how are they compared to putting on the f & r?
Are you suppose to drill into the car itself?
Old Apr 28, 2008 | 07:08 PM
Andpto's Avatar
Andpto
Default RE: Mopar side skirts??
yes you drill into the car. make sure you measure twice.
Old Apr 28, 2008 | 07:12 PM
AirWolf's Avatar
AirWolf
My husband and I are going to attempt to put some r/t sideskirts which are the ones you have on whenever I get them painted at a bodyshop.
Old Apr 28, 2008 | 07:31 PM
2003SXTneon
you have to cut the mud flaps alittle right?
Old Apr 28, 2008 | 07:49 PM
Freerider's Avatar
Freerider
ORIGINAL: 2003SXTneon
Yes you need to modify the mudflaps a little bit.
And airwolf, the R/T Sideskirts are the same as the Mopar Lip Kits Side Skirts.
Old Apr 28, 2008 | 08:04 PM
AirWolf's Avatar
AirWolf
Thats what I said I knew they both were the same way back in 04 when the lip kit 1st came out with the tuner package.
Old Apr 28, 2008 | 11:50 PM
2003SXTneon
cool thnx
Old Apr 29, 2008 | 11:08 AM
AirWolf's Avatar
AirWolf
Well Im going around to some bodyshops today and see how much they will charge to paint my sides and if to expensive my husband can do them nicely. So my whole kit should be on in the next few weeks . pics will be in my gallery when shes finshed.
Old Apr 29, 2008 | 02:19 PM
Freerider's Avatar
Freerider
They require a special primer. Or atleast this is the D/L on my parts:
When i got my parts in I decided to look into paint, but you need to know what your parts are made out of so you can get the right primer.
Whent and looked it up, and turns out that the parts are made out of a special material that doesn't bond to typical primer. It is a special, expensive, kind of primer. So what I ended up doing was getting some wet sand paper, and wet sanding down past the clear coat on my original parts and then re-painting them.
It worked well. Unfortunately my front end got a little chewed up (Highway Driving + semi's + VERY dusty and rock filled roads = terror for front end).
So, I will be RE-painting it soon
