What sparkplugs are you guys running with!
Old May 2, 2008 | 11:45 AM
AirWolf's Avatar
AirWolf
Default What sparkplugs are you guys running with!
Its time for my gal to have a small tune up so just waundering what plugs I should go with . I have some really awesome msd wires so no need to change those.
Old May 2, 2008 | 12:47 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: What sparkplugs are you guys running with!
NGK.... bkr7e, but those are a heat range colder because of the turbo setup...
Old May 2, 2008 | 01:37 PM
Adionik's Avatar
Adionik
ORIGINAL: dtjackten
They must run super cold with the engine ya know....not turning over or anything
I run NGK
Old May 2, 2008 | 02:50 PM
dtjackten's Avatar
dtjackten
accually that is ONE heat range colder than stock? stock plug is a bkr6es, and ngk run opposite in colder heat range so one higher number is a COLDER heat range plug.. and if it is a lower number then it is a hotter plug...
so one heat range is not going to affect anything including starting and performance, accually one lower heat range plug is better in a turboed application due to non detination.....
Old May 2, 2008 | 03:17 PM
contagious19's Avatar
contagious19
Old May 2, 2008 | 09:07 PM
inthewerks's Avatar
inthewerks
i run the stock champion plugs i buy em from the dealer
Old May 2, 2008 | 10:57 PM
ewetho's Avatar
ewetho
Either use Champion or NGK and be done with it.
I know I know Champions only work in Chryslers and lawn mowers but it is a Chysler!!!
Old May 3, 2008 | 07:30 AM
dtjackten's Avatar
dtjackten
very true
Old May 3, 2008 | 08:46 AM
03neonRT's Avatar
03neonRT
Denso Iridium plugs for me...
Old May 4, 2008 | 01:54 PM
spec_ops57's Avatar
spec_ops57
I went full out with the Bosch Platinum 4+ plugs..
They don't make any difference at all
