grounding kit
Old May 7, 2008 | 12:11 AM
inthewerks's Avatar
inthewerks
Default grounding kit
hey everyone. i posted a while ago about a hyper grounding kit i saw on ebay. well, i did some research and found out they are crap. the right way to upgrade your grounding system is to use a high copper thread count to reduce resistance in the travel of current. well i bought and installed a good grounding kit today. costed me 50 bucks from a local motorsport shop and the product is made by LINEAGE. its four guage wire, 1,821 copper strands and the wire is sottered to the terminals that are dipped in platinum. there are five wires of different length and and get connected in series from chassis to alternator to head to block to battery to chassis. very clean setup. the best part is that i DID notice a difference with them. and no its not some placebo effect. although i didnt notice an increase in horsepower, my throttle response is better(that hesitation from a cai install is gone), headlights are brighter and dont dim at a stop with the stereo blasting, stereo sounds cleaner at higher volume, and the engine idles alot smoother. if you want these gains without worrying about hp increase, then you should try these out. just make sure the wire is a high copper thread count. and dont get those crappy 8 guage wire ebay setups. will definately post install pics with grounding locations tommorrow.
Old May 7, 2008 | 09:22 AM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Default RE: grounding kit
Dam sounds nice. How long did it take to install?
Old May 7, 2008 | 09:52 AM
inthewerks's Avatar
inthewerks
about an hour. the only ground spot that was even remotely difficult was the bolt on the cylinder head right above the alternator. should have let the car cool down first.
Old May 7, 2008 | 10:31 AM
underground6t9's Avatar
underground6t9
I have the Apexi super grounding system on my ride and I did notice an increase in hp and throtle response. It was 180 at MP.
Old May 7, 2008 | 10:35 AM
blackflame's Avatar
blackflame
dang that sounds sweet. That hesitation from the CAI has been really pissing me off lately. before 2000rpms its like my car is dead.
edit: do you have the links?
Old May 7, 2008 | 11:19 AM
KARR's Avatar
KARR
How good is that Optima battery?
Old May 7, 2008 | 11:52 AM
underground6t9
Optima batteries are the best, it is awesome, never had any problems with battery even in cold weather. I have had it for almost four years now.
Old May 7, 2008 | 01:14 PM
Baddog44's Avatar
Baddog44
ORIGINAL: KARR
the best performance battery u can get
Old May 7, 2008 | 03:18 PM
inthewerks's Avatar
inthewerks
i guess it does give a little more hp. but i think its mostly due to the fact than the throttle response is better and the engine is smoother so it hits bigger rpms faster. i should dyno my ride with and without the grounding kit to really see the difference. if i was to guess at hp increase, maybe the same as the cai mod gave me. 5-10 hp??
Old May 7, 2008 | 03:49 PM
Adionik's Avatar
Adionik
I changed out my windshield wipers and got like 1-2 hp
