Won't start on hot days
I have a 2005 Neon and when the interior is hot (Not a long period in Maine) the car won't start. I have tried shifting it into neutral and I hear the fuel pump kick in at start but nothing to the starter. The battery was was replaced in February and I have checked the relays. The car is now in the shade and the windows are open and now I"m good to go. I was thinking the key switch somehow doesn't like the heat. I go to work early in the morning and it is cool. When I get out the car is shaded and it starts. If I go to the mall and it sits in the sun the car will not start.
Any help will help
Any help will help
My 2000 neon will not start on hot days...no crank, but I get power to dash. Ignition switch has been replaced. This problem only happens when the car sits in the sun on warm days. Problem started happening last fall...had no problems all winter. Now with the return of warm weather it is happening again. Any Ideas?
Any ideas anyone help dont make since
I think its the safty neutral switch i think there is water in it i by passed it at starter relay car started up will pull off and check out later in a few days to make sure will repost after
