03 neon pivot bolt broke
Old May 7, 2008 | 11:13 PM
Beasty's Avatar
Beasty
Default 03 neon pivot bolt broke
ok my friends 03 neon 2.0 pivot bolt i guess is what its called im not sure but you have the two motor mounts on top and bottom well this bolt is inbetween them located in by the tire. well it broke im assuming that the bolt isnt that long going into the block so i think i can extract it by taking that bracket off for the belt system i got two of the bolts out i can get the bracket to move but one bolt still remains and its located on the backside of the motor the bolts r about 2 inchs long and i have to get it out in a space the side of about 1/2 inch any tips on how to get that bolt out without removing the engine itself? cuz im clueless now i tried many things and none worked...... i cant even get a ratchet or wrench in there to even loosen it up and remove it with my fingers.... so if anyone can PLZ HELP.
