Sub Problem
Old May 11, 2008 | 05:47 PM
00Neon89's Avatar
00Neon89
Default RE: Sub Problem
i just went to check it and my amp turns off wheni turn the car off
Old May 11, 2008 | 10:52 PM
neon riders's Avatar
neon riders
YEAH YELLOW IS THE PRIMARY 12V WIRE
Old May 11, 2008 | 10:58 PM
Izero's Avatar
Izero
oy... comon people... ok if the amp doesn't see that the car is turned on it wont let the subs go on b/c it will drain the battery in a few min... so if you want your subs to work you gotta rewire your amp, there is a few how-to's all over the place... mine does the same thing... and usually i have to reset my amp with the car turned off before my subs will turn on again.... just pull out the fuses on the amp with the car off and wait 30 seconds or so and put em back in.... and that should fix the problem....
Old May 12, 2008 | 06:59 AM
Baddog44's Avatar
Baddog44
lol i think he fixed the problem izero
Old May 12, 2008 | 01:24 PM
00Neon89's Avatar
00Neon89
i fixed it i hooked it right to the power wire and it works fine i left it like that all night an it started no problem this morning
Old May 12, 2008 | 04:26 PM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Dam Izero doesnt that get annoying? I would just get another Amp if I had to do that.
Old May 12, 2008 | 09:37 PM
Izero's Avatar
Izero
no... why do i need to listen to the radio without the car started...? i mean i dont like play music while im working on the car or anything.... radio is on while im driving so i listen to it then... i dont have a problem with it...
