04 neon sxt Stopped running out of blue ADICE PLZ
I have a 04 sxt neon (87.000 miles)that will not start. had started tested as well as battery and alternator are all fine!. Lights, ac, and radio turn on but the car will not start not even a attempt to turn over or anything. It will not give off any codes on the odometer it just goes directly to done then ------- appears. the engine sign blinks and oil light on. but oil level is great. Oil was changed a few months ago could probulay do it again its getting kinda dirty. But level is perfect. We have no clue what is wrong with this car. Has anyone had any experence like this before or know someone that has or just has a clue what happened. Ive been reading up and friends have told us could be ignition switch, computer went out, or sludge oil in the engine. Dodge dealership told us not to spend the money on a new ignition till we get it checked out. anyways if you have any adivce or tips i am very open to hear thank you!
RE: 04 neon sxt Stopped running out of blue ADICE PLZ
I used to have this probelm alot of times. The problem with my car was that corrosion started building up on the terminals. It wasn't noticeable from the outside bcause it was forming in the cracks. so i simply removed the corrosion by either coke or sanding it off. and then my car started working just fine. It might be that along with loose connections. make sure all connections are tight and rust free and corrosion free so that you can have the best conductivity.
