Seafoam?
Old 05-14-2008 | 11:24 PM
Adionik's Avatar
Adionik
Default RE: Seafoam?
Works really good
Use the line that is on the intake manifold after the TB.
Matt - No you'd be fine
Old 05-15-2008 | 01:51 AM
Mat00ES's Avatar
Mat00ES
Im gonna try this tomorrow, Im at 1/4 of a tank. Should I fill up, then put the seafoam or the other way around? Also to put it in the PCV, just leave the car runningand let it suck it up?
Mat
Old 05-15-2008 | 02:36 AM
Adionik's Avatar
Adionik
Put some in, then fill up.
Yeah, car has to be idling when you put it in the PcV. it's going to want to die and the idle will get rough. let it all suck in and then kill it. let it sit for ATLEAST half an hour. the longer the better.
Old 05-15-2008 | 09:35 AM
Mat00ES's Avatar
Mat00ES
Alright I just did, I think I did it right. Im letting it sit right now. When I reconnected the pcv line the motor died. I went to restart it smoke was coming from my engine, Im hoping its because I have an exhaust leak. Im gonna let it sit for 30 mins, then see if I royally ****ed up my car or not. Ohh little side note, dont get seafoam in your eyes, it burns like a bitch.
Maat
Old 05-15-2008 | 03:26 PM
Kalevra's Avatar
Kalevra
Smoke is normal let it smoke out
Old 05-15-2008 | 11:00 PM
Mat00ES's Avatar
Mat00ES
I was coming from under my hood, I now know I have an exhaust manifold leak. Alls good, car idles perfectly now. I made the car stop behind me when I got on it, so much smoke came out.
Mat
Old 05-15-2008 | 11:43 PM
12 volt's Avatar
12 volt
just for kicks
http://video.google.com/videoplay?do...90865726229173
its a good idea to change your oil after you finish foaming
Quick Reply: Seafoam?
