i need an opinion
Old May 19, 2008 | 09:13 PM
Izero's Avatar
Izero
Default RE: i need an opinion
if you want/have subwoofers you will have trouble powering them b/c the underdrive pulley will underdrive the alternator which wont charge the battery with the req. power to power the amp & sub(s).... look for an underdrive pulley that is the same diameter as the stock underdrive pulley but just lighter... then you wont have any problems...
Old May 19, 2008 | 09:42 PM
mannyfresh18's Avatar
mannyfresh18
oh ok.
thanks.
Old May 20, 2008 | 02:55 AM
contagious19's Avatar
contagious19
if u dont have an intake get one instead of the pulleys
Old May 20, 2008 | 04:42 PM
mannyfresh18
alrite.
well it dont matter anyways because im going to start on a little engine project for my car soon anways.
but thanks for the advice.
Old May 20, 2008 | 04:53 PM
underground6t9's Avatar
underground6t9
I habe the TB from modern performance and its awesome, I also got the UDP from them too. I put and r/t intake manifold in my car and I think it works just as good as the indy one. I got my manifold for 100 from a junk yard. Check out the pics of the manifold and tb.
Old May 20, 2008 | 05:18 PM
Izero's Avatar
Izero
where did you get that radiator hose?!!?!?!?! i've been looking everywhere for those hoses!!! damnit! i've also been considering getting an r/t manifold and polishing it up like that.... was it a pain to polish it or what?
Old May 20, 2008 | 05:56 PM
underground6t9
Its just asleeve hosekit that you can get at any autoparts store. Its alot of hard work to polish it up, alot of sanding. I would recomend wet sanding because it dosn't scratch up the metal but its more hard work. The end result is awesome as you can see.
Old May 20, 2008 | 09:00 PM
03neonRT's Avatar
03neonRT
Throttle Body and UDP, yes...INDY, not so much.
I would just buy a custom AMM or LoneWolf manifold personally. A guy on 2GN had a LoneWolf installed a long time ago and that thing sounded incredible.
Old May 20, 2008 | 09:07 PM
Izero's Avatar
Izero
i haven't been able to find a sound clip or anything of a neon with one of those manifolds on it... else i'd have bought one awhile ago
