what is this exactly?
Can you tune your car with this product, rpms, air fule ext?FUNCTION
Or is it just a display, and warns you.
KNOCKING MONITOR
The new Super AFC-II has a new knock sensor function which alerts the driver. This ensures that the engine is tuned to perfection at every stage. This function only works on vehicles that has an engine knock sensor.
MEMORIZE 2 TYPE OF SETTING DATA
The new Super AFC-II can save two data setting from data collected with respected to air flow adjust rate, throttle duration, engine RPM, etc. The driver could use these two settings in a variety of driving conditions, be it track, street, or just plain cruising.
WARNING
The driver can set up various warning functions in order to monitor the engine operation. These functions includes incoming air flow rate, suction pipe pressure, engine knock RPM, etc.
Others
Settings & data stored in the new Super AFC-II will not be lost even if the it is disconnected from the vehicle battery power.RMP signal for air flow & pressure sensors can be adjusted in 12 points in 1% increments depending on fuel settings in +50% to -50%. Or the RSP can be set in increments of 200 RPM. Throttle opening duration: Adjustable by size.
[IMG]local://upfiles/8577/93129BC3EAA049DAB55D44FB212F74A7.jpg[/IMG]
KNOCKING MONITOR
WARNING
Others
