neutral safety switch
Old May 24, 2008 | 08:25 PM
mjs182004's Avatar
mjs182004
Default neutral safety switch
does anyone know where the neautral safety switch is located? I have an 02 neon es w/ automatic trans with overdrive.
Old May 25, 2008 | 05:45 PM
culthuu's Avatar
culthuu
Default RE: neutral safety switch
I have a 2000 and the interlock is on the bottom of the steering column and connected to the shifter by a seperate cable. It might be the same on you vehicle but since the transmission is different you milage may vary.
Old May 25, 2008 | 08:38 PM
SXTJunk's Avatar
SXTJunk
I don't know right now but when i go to work tommrow ill look it up and try to find it for ya. We have acces to oe repair manuals that pritty much tell you where everything is.
Old May 27, 2008 | 08:26 AM
SXTJunk's Avatar
SXTJunk
Looks like in is on the transmition.
