Headlight Bulb's on 2004 Neon
Old Jan 18, 2005 | 02:19 PM
keithamos's Avatar
keithamos
Default Headlight Bulb's on 2004 Neon
How do you get to the drivers side headlight to replace the bulb? I was barely able to reach the passengers side, the drivers side is blocked by the airbox and etc. I want to replace both with Silverstars for now. Thanks for the help......
Keith
Old Jan 18, 2005 | 02:21 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Headlight Bulb's on 2004 Neon
You have to take the headlight out. You'll need to take out the two screws holding it in, and a few of the fascia screws on that side to get it out. You have to pull back the front fascia slightly to get it out. Because the headlight itself has a hunk of plastic attached to it that goes into the frame. Just take a look at it, you'll see what I'm referring to.
Old Jan 18, 2005 | 02:27 PM
casper's Avatar
casper
that is one of the things that I hate about our cars. They are such a pita. But yeah if you pull the light its easier to get at.
Old Jan 19, 2005 | 12:45 AM
morningpride's Avatar
morningpride
On a 04. all you have to do is take the cover off of the air box, and remove the intake cone, (the one with the temp sensor in it.)
That will give you enough room to weasel your hand in there and get the bulb out.
Old Jan 19, 2005 | 12:49 AM
LowSlowNeon
I never tried that or thought of that. I should be able to change mine now easily, I took my airbox out.
Old Jan 19, 2005 | 01:18 AM
morningpride
Yup,
You can squeeze your hand right in there....
Works really well.....
Old Jan 22, 2005 | 11:09 PM
nippondrifterae111's Avatar
nippondrifterae111
u should get m tech halogen bulbs 9007 they r the best in brightness and blueness and cheap
Old Jan 23, 2005 | 03:25 AM
gman79's Avatar
gman79
How do i go from the original orange flashers to the blue ones in the picture. How much will the bulbs cost? Any additional wiring
Old Jan 23, 2005 | 02:01 PM
shneeko6's Avatar
shneeko6
those are silverstar bulbs. just take out one of your turn signal bulbs and bring it to an Advance auto parts or a store simialr to that and match the size up. itll run around 20 bucks or so.
Old Jan 23, 2005 | 02:22 PM
LowSlowNeon
Actually those are not silverstars. How do I know this may you ask? Maybe because thats my car. They are APC hyperwhite bulbs.
