DOES 2003 NEON NEED A CHIPKEY?
Old Jun 12, 2008 | 01:02 AM
KIMSTRAIN's Avatar
KIMSTRAIN
Default DOES 2003 NEON NEED A CHIPKEY?
Does the 2003 Neon need a chipkey or can I just go get a regular spare key made? Anyone know? Thanks..
Old Jun 12, 2008 | 02:00 AM
Exubus's Avatar
Exubus
Default RE: DOES 2003 NEON NEED A CHIPKEY?
Yes, you need a coded transponder key, i.e., "chipkey" for your car if you plan on using it in the ignition... should be a standard item for a 2003... if anyone knows of any reason why you wouldn't please correct me because I haven't seen it.
Old Jun 13, 2008 | 01:09 PM
DaHipaKea1313's Avatar
DaHipaKea1313
Hey all
I just bought a 2004 Neon and I guess that you can only get a "Chipkey" any idea how much they are and if a dealer is the only place to get one??
Old Jun 17, 2008 | 11:41 PM
neon chic's Avatar
neon chic
yes u can only get it at the dealer and ur looking at about $50. You can also do what i did and get a couple of regular keys made at lowes or somethin just in case u lock your keys in your car. they only work in the doors but at least you'll be able to get into the car
Old Jun 17, 2008 | 11:46 PM
N30N's Avatar
N30N
ORIGINAL: neon chic
also you can get a key made at a lock smith.they will only charge you 40-50 bucks.you can go there only if you have the key still good.if the keys not good then you'll have to get it re-programmed
