Project SRT wheels
Old Jul 30, 2008 | 03:22 PM
  #151
Exubus's Avatar
Exubus
Default RE: Project SRT wheels
42? A bit on the higher side dont ya think?
Old Jul 30, 2008 | 03:29 PM
  #152
Captansavaho's Avatar
Captansavaho
the psi on my 215/40/17 is like 50 psi
Old Jul 30, 2008 | 06:28 PM
  #153
Exubus's Avatar
Exubus
ORIGINAL: Captansavaho
the psi on my 215/40/17 is li ke 50 psi
Whats the service rating on your tires?
have you guys ever chalked them?
Old Jul 30, 2008 | 09:41 PM
  #154
srtgtr34's Avatar
srtgtr34
Tires say max 50 and even if it were to get hot down there the psi still wouldn't go past 47, i hope. lol
Old Jul 30, 2008 | 09:52 PM
  #155
Exubus's Avatar
Exubus
Well I understand that, mine also have a max fill of 50... and I also have 205/40/17"s, but anything over 32 in the back and I get obvious uneven treadwear (bulged tire) which is also verified by chalking. Anything over 37 or so in the front starts doing the same thing for me... just saying.
Old Jul 31, 2008 | 02:45 AM
  #156
contagious19's Avatar
contagious19
chalking?
Old Jul 31, 2008 | 02:54 AM
  #157
Exubus's Avatar
Exubus
ORIGINAL: contagious19
chalking?
"Chalking," the term used. You could us e real chalk, but sand, dirt, or anything else works just as well. Basically clean the treads of your tires up, then drive your car straight on flat ground/pavement through it. The dirt/sand/grime/debris/chalk/whatever will make contact with the tread and stick to it... and make it obvious to show wher your tread is touching the ground as you roll. If for example you do this and you only have a 3" wide "chalk" spot onthe center of yourtire all the way around, then you are probably are over-inflated...
Old Jul 31, 2008 | 09:57 AM
  #158
N_gin's Avatar
N_gin
Those look awsome wow. Thats a long time to be rubbin on metal. I think after about 10 minutes I would have gotten the DA sander out. I believe you can get the surface straighter using DA then your fingers, and a hole lot faster too..
Old Jul 31, 2008 | 11:03 PM
  #159
srtgtr34's Avatar
srtgtr34
ORIGINAL: N_gin
Thank you! I did u s e a sander, a black and decker mouse which took me even longer because i paid more attention to the details.
Old Jul 31, 2008 | 11:06 PM
  #160
srtgtr34's Avatar
srtgtr34
You guys would love to know what I have planned next...
