o2 simulator
Old Jul 16, 2008 | 01:11 AM
redbirdhky6's Avatar
redbirdhky6
Default o2 simulator
hey i gotta go thru emmissions coming up. does anyone know if they make an o2 simulator for neons. i know they do for mustangs and **** like that so that they can pass but ive never seen them for neons.
Old Jul 16, 2008 | 07:00 PM
Pablodragon's Avatar
Pablodragon
Default RE: o2 simulator
wow, I remember emissions tests from when I was little...
but can't help you there... here, we don't have emissions tests, car inspections, or even front liscense plates!
Old Jul 16, 2008 | 09:05 PM
Andpto's Avatar
Andpto
go to the top of thread
https://dodgeforum.com/m_727544/mpag.../tm.htm#728767
Old Jul 16, 2008 | 09:24 PM
Exubus's Avatar
Exubus
If you want something a bit more slick and much more accurate/adjustable/reliable, getcha an EFIE box, like this one:
http://www.pwmpower.com/efie.html
Basically you run the signal wire from your O2 sensor into it, and the EFIE box has trimable pots on it to adjust the the signal up or down... its constant variable with the incoming O2 signal, so lets say your O2 sensor is reading 0.4 volts at a given second, and you want to lean your car out... trim the pot back on the EFIE, and it will output 0.2 volts to your computer instead... the voltage will rise and fall accordingly as your O2 sensor oscillates within its operating band. Same premise goes for wanting to run more rich...
You can find those pretty cheap on Ebay too. Some people are using them for Hydrogen injection or HHO gens, but you can use them for just about whatever really. This is probably the best way tomoderately tune a naturally aspirated NGC without without spending lots of money... you can also build one a bit cheaper if you have electrical knowledge. I have the schematic on my computer at work...
Old Jul 22, 2008 | 05:23 AM
redbirdhky6
has anybody done this and how difficult/successful was it?
