Mods Please Read
Old Jul 29, 2008 | 12:30 AM
  #71
Exubus's Avatar
Exubus
Default RE: Mods Please Read
ORIGINAL: mat663
Was it because your motor mounts were in bad condition? I wonder if I should change mines too. I don't really have any experience on them though.
The upper torque mount was beginning to crack, just slightly. I decided to fill it to stiffenit up a bit, or at least supportit a little better. I did the lower as well. I get a bit of "spring" in my shifts from time to time. I also have a small bit of play in my differential that gets on my nerves and exaggerates this problem. I figure any little bit could help.
Old Jul 29, 2008 | 01:11 AM
  #72
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Man I could just have my cousin and uncle look at mines and tell me whats up with them.
Old Jul 29, 2008 | 01:28 AM
  #73
Exubus's Avatar
Exubus
ORIGINAL: KARR
maybe you should quit pullin on it he he he he he he he he he he he he he he he he he he
No seriously, you can check it yourself. Upper torque mount right next to the fill cap for your washer fluid. Lower mount directly underneath the pulleys on the bottom of the car... there is a thin splash-gaurd covering it. Look for cracks/seperations in the rubber that are not supposed to be there. If you see none, you are good to go.
Old Jul 29, 2008 | 05:08 PM
  #74
KARR's Avatar
KARR
Ok. Yeah I hate how that pulley and belt is so low to the ground. I believe mines are good, but Ill have to check for sure.
