engine code p0480 cooling fan circuit malfunction....FIX
Old Aug 11, 2008 | 05:17 PM
the_jones_670's Avatar
the_jones_670
Default engine code p0480 cooling fan circuit malfunction....FIX
How do i fix this problem. The cooling fan works, sort of, its just constantly on, until i shut the car off. i did the engine code test, turnin the key on and off, and thats what i came up with, and id really like to get this light turned off. thanks for the help
Old Aug 12, 2008 | 12:53 PM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
ELECTRIC RADIATOR FAN
OPERATES ALL THE TIME.
1. Fan relay, powertrain control
module (PCM) or engine coolant
temperature sensor defective.
1. Refer to appropriate Powertrain
Diagnostic Procedures manual for
operation of the DRB scan tool.
Repair as necessary.
2. Check for low coolant level. 2. Repair as necessary.
Old Aug 12, 2008 | 08:02 PM
Exubus's Avatar
Exubus
Yup look in the TDP manual and break out that DRB scan tool, then repair as necessary... that explains everything. LOL j/k.
I'm not busting anyone's *****, but this is one of the reasons I am not copying and pasting the DCX stuff much on here, instead of using my own words. If you don't proof-read what it is saying, it can be a bit misleading to someone who doesn't know much about Neons, or cars in general, or to someone who is having a specific Neon-related problem and is looking for specific answers or ideas...
This one is probably a much less-involved fix that that... I would guess the coolant temperature sensor is a good place to start, then check the relays in the PCM... and go from there... I wouldn't worry about the manuals or scan tools, since you can complete what you need to do without them.
Old Aug 12, 2008 | 09:02 PM
KARR's Avatar
KARR
Or what he said. LOL
Old Aug 12, 2008 | 09:04 PM
KARR's Avatar
KARR
Hey at least I helped. No one else would touch this thread. Thats what this site is about helping people. LOL
Old Aug 12, 2008 | 10:09 PM
Exubus's Avatar
Exubus
+1 ...
I agree, we need more knowledgeable members helping people, instead of turning every thread into an OT thread all the time lol.
But good eye on helpin out, you are right, that's what its all aboot.
Old Aug 12, 2008 | 10:36 PM
KARR's Avatar
KARR
Thanks. I feel so special. LOL Naw serious Thanks Iowa.
Old May 2, 2018 | 12:42 AM
tony69's Avatar
tony69
Angry
P0480 Cooling Fan 1 Control Circuit Malfunction I have this code on my 2009 ram 1500 5,7 and the fan was replaced and the relays are clicking when I checked them with a nine volt battery. The water temp goes up and down depending on the drive conditions and the air temp. When I turn on the A/C the fan does not come on and when the engine water temp goes past 195 deg. the fan does not come on. I ned help !!!!
Old Jan 15, 2020 | 12:17 PM
ABanx's Avatar
ABanx
Hi Tony69, It looks like you never got a reply to this post, is that correct? I have the same issue right now. If you got this solved can you tell me what happened? I see that it is almost 2 years ago. Thanks
