Exhaust Question
Old Aug 12, 2008 | 11:41 PM
MaSeDaDdY's Avatar
MaSeDaDdY
Default Exhaust Question
my current setup is a single fireball type muffler, yes a fart cannon i know, with a header and cold air intake, i notice performance improvements, but i was wonderin how much of a difference would a dual exhaust make performance wise....
Old Aug 13, 2008 | 12:31 AM
Izero's Avatar
Izero
dual exhausts reduce backpressure so you may see some gains... you'd actually see more gains if you went turbo with a dual exit exhaust... don't make me go into the flow dynamics of it....
Old Aug 13, 2008 | 01:02 AM
djmagic's Avatar
djmagic
go go go izero i want to hear. No seriously though i agree with the backpressure thing. Look at it this way with a single exit it HAS to go one way. However the dual isnt forcing the pressure as much as the single
Old Aug 13, 2008 | 01:11 AM
Izero's Avatar
Izero
well with the SRT-4 rear section there is no vaccuum on either end b/c the exhaust splits into two and has an exactly symmetric shape all the way to each tip... so the air actually speeds up... i forget the factor it speeds up by... yes there is a formula to figure it out but it involves me pullin out my fancy calculator and school doesn't start again till like Sept. 1st or something so deal with it :-D basically for example... if you have a 3.5in. pipe and you put a gas through it and with the same type of gas at the same pressure put it through two 1.5in or 2in pipes the 2 pipes will actually flow much much faster and efficiently then the single... now im putting this crap into the dumbest down version i possibly can so deal with it till i get back into school mode and actually attempt being intelligent... and sober :-D he....he....he....
Old Aug 13, 2008 | 01:21 AM
djmagic's Avatar
djmagic
????? Sorry i asked for the explanation, could just be the tiredness
Old Aug 13, 2008 | 01:34 AM
N30N's Avatar
N30N
yea i have a single.if you do dual make sure its a Y pipe off the cat because it adds more flow.some people will have it where it goes manifold and then a pipe to the cat and then a pipe halfway from the cat there will be a Y pipe for the dual to the back.the way you can tell is in the winter the left pipe blows more smoke/steam then the right.just whatever you do make sure you do it off the cat please....Good luck
Old Aug 13, 2008 | 01:36 AM
N30N's Avatar
N30N
i might get this done...who knows
Old Aug 13, 2008 | 01:39 AM
N30N's Avatar
N30N
and does anyone know if dual straight pipes would be louder then a strait pipe???
and bro get that fart can off NOW LOL
Old Aug 13, 2008 | 03:44 PM
Izero's Avatar
Izero
if you go with a y-pipe from the cat, you will have to bang out a new section for the second pipe to fit.... so basically a y-pipe from the cat back would sound nice and reduce backpressure/increase flow but it is gonna take some SERIOUS work for it to work DO IT!
Old Aug 13, 2008 | 08:47 PM
night709's Avatar
night709
I have the section from an SRT-4 and it is amazing. Should go that way if you could, if that sounds good to you.
