oil opinions
Old Aug 20, 2008 | 02:43 AM
  #41
djmagic's Avatar
djmagic
ok thats what i thought cause i looked in my manual and it told me 10w30 cause of the constant heat
Old Aug 20, 2008 | 02:54 AM
  #42
Exubus's Avatar
Exubus
In your case with the heat, you would be fine with 10W-30.
Old Aug 20, 2008 | 04:11 AM
  #43
djmagic's Avatar
djmagic
alright man and nice avatar
Old Aug 20, 2008 | 09:33 AM
  #44
2000LX's Avatar
2000LX
Originally Posted by IowaNeon04
You should run 5W-30 in it all the time... stay away from 10W-30...
question - why do you say that - Just asking.
just want to see what your opinion is.
Old Aug 20, 2008 | 08:29 PM
  #45
Exubus's Avatar
Exubus
Because unless you live in a real hot environment like djmagic does, it is not necessary. In more moderate climates across the U.S., the temps are cooler (and in some places in the winter, down-right f*ckin-a cold). The 10W-30 at startup in those conditions is a lot thicker than the more resistant winter-weights are. In a "normal" summer during normal driving, it is still thicker than 5W-30, etc.
DCX called for this motor to take 5W-30 for a reason. The tolerances in the motor are a bit tighter, which makes the 5W-30 more accessable to critical surfaces than the 10W-30. Also, auto companies got really tired of doing catalytic converter warranty work... 10W-30 put in our 2.0-liters will generally go out of the exhaust a little more than 5W-30 or a lighter winter-weight will, and obviously go through the cat.
With these engines, under normal driving in normal climates, I would stay with the recommended 5W-30 or the 0W-30 FTW.
Old Aug 21, 2008 | 04:51 PM
  #46
lblackneon's Avatar
lblackneon
I've been contemplating on oil the past few days too. I've been running Mobil 1 majority of the time but I think I'm going to start putting AMS oil back in my cars. I've been reading lots of good stuff about it and think I want to go back.
Anyone have any input on AMS oil?
I would never push my car 10k+ or even close on one oil change.
Old Aug 22, 2008 | 03:52 AM
  #47
Exubus's Avatar
Exubus
Before I pushed mine that far, I never went past 3k miles, even though it was synthetic... I probably won't ever go that far again, ever, but I must say I was surprised how it held up. I wouldn't trust that all the time though, no sir... but still, it was food for thought considering the results.
I knew a guy once who used to be a mechanic for the Miss Budweiser hydroplane. He would just spin the filter off of that thing, add one quart and be done with it. He always swore by it. That's definitely food for thought too... although I never did try it lol.
Old Aug 24, 2008 | 02:50 AM
  #48
N30N's Avatar
N30N
now in the winter you want to run a thicker weight right???
ill switch back to 10w-30 when the cold comes
Old Aug 24, 2008 | 02:58 AM
  #49
smallblockfreak's Avatar
smallblockfreak
I changed my oil today and i run 10w 30 valvoline with a quart of lucas oil stabilizer. I over went my oil change due to income and well i changed it today with 6,000+ miles. Drained it and stuck my finger in the way and to my surprise it was slightly tinted black. My roommate changed his rotella t in his truck that has been in there for a year and it was black completely and had less miles on it than me.
Old Aug 24, 2008 | 03:02 AM
  #50
N30N's Avatar
N30N
what oil did you have in there before the change bro???
