Best/easiest swaps???
Old Aug 25, 2008 | 11:06 AM
LouzNeon305's Avatar
LouzNeon305
I also have heard of boomba motor mounts but tried to find them online and couldnt....
Old Aug 25, 2008 | 11:51 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
same here... if u look at neonon19s progress thread i think he tells u...
Old Aug 25, 2008 | 11:52 AM
LouzNeon305
ok no problem so ur neon is 400 whp, impressive. got pics??
Old Aug 25, 2008 | 12:05 PM
dtjackten's Avatar
dtjackten
in progress, check out my thread...
https://dodgeforum.com/forum/2nd-gen-neon/163217-dtjackten-offical-progress-post.html
it is not done yet, hopin april..... have to save up the money for a bottom end and tranny...
Old Aug 25, 2008 | 06:15 PM
LouzNeon305
would boosting my sohc rather than doing the swap be a quality alternative??
Old Aug 25, 2008 | 06:26 PM
djmagic's Avatar
djmagic
not really. if you had a 00-02 i would say possibly. However the computer between yours and mine are different. You comp eliminates the performance gains more than mine to stay fuel effeicent. We had a former member graphite who i think got 280 something going turbo and freerider who i havent see forever was trying to get in that range. I think that is why dtj is able to get 400 cause his is an 02. So for you i would say a swap is more reasonable
Old Aug 25, 2008 | 06:38 PM
LouzNeon305
So changing my cpu isnt an option to get the full gains out of the turbo?? If its even possible...Does that mean adding headers, exhaust system and/or any other performance parts make the results be limited as well??
Old Aug 26, 2008 | 10:50 AM
dtjackten's Avatar
dtjackten
U have to get a different computer system, such as ms... u can not run a turbo set up for that much power with ur stock ecu.. reliablility will not be the best for a 2.0 either, UNTILL u get it tuned properly.... i have been stuck on the side of the road once, due to me messing with settings and hitting the safc wrong.. also oil leaks, was a big problem for me... was a pain in the *** for a while.... got everything fixed and i was happy....
i have built my turbo setup, peace by peace, and i have about three thousand in it, just to give u an idea... it took me around a year to put together... that does not include the headwork, or bottom end and tranny that will be done to it in the near future... i honestly am looking at around a 8k drivetrain when it is all said and done... will it be worth it???? i sure hope so...
Old Aug 26, 2008 | 10:51 AM
dtjackten's Avatar
dtjackten
by u can not run a turbo on ur car without an aftermarket setup i was meaning big power such as 400. and it be realiable, u do not need a ms or safc to run low boost 5-8psi.... anything after that i would recomend some kind of management system..
