2001 Neon Error code: Downstream not matched
Old Sep 9, 2008 | 08:44 AM
spec1sef's Avatar
spec1sef
Unhappy 2001 Neon Error code: Downstream not matched
Car sputters and loss of power.
Check engine light comes on.
I forgot the exact code number but it said "Downstream not matched".
I know it has to do something with O2 sensor.
So can a bad O2 sensor make the car loose power?
What if I disconnect the downstream sensor?
Or how can make sure that its O2 sensor problem?
Car makes backfire pops if I gun it.
Checked the spark plugs, wires, fuel, all seems to be working right.
Car just don't wanna accelerate but if I really push it and let it pass 3500 rpm all of a sudden it picksup and feels powerfull.
Old Sep 9, 2008 | 09:33 AM
spec1sef's Avatar
spec1sef
Default CEL Code: P1684, P0301
I went back and checked the engine codes.
Apparently the O2 downstream code is gone after the new Catalytic converter install.
But now one more code showed up.
P0301 which I found out means
"Misfire Detected, Cylinder No. 1"*
The P1684 simply means that the battery was disconnected within last 50 starts.
Now what do I do about the misfire in cylinder 1?
Get new plug wire or how do I diagnose it?
There is definately something going on because car feels like slower than a 1.6 litre* engine and sputters.
*Found the codes detail on the following web:
http://answers.yahoo.com/question/in...9195234AA7qibL
Old Sep 9, 2008 | 10:29 AM
2000LX's Avatar
2000LX
what plugs are in it?
How old?
Wires - how old?
Both are rather cheap to replace
Old Sep 9, 2008 | 01:57 PM
djmagic's Avatar
djmagic
could be the wires, i know i put on grantinilli ones and i kept getting a misfire. But when i switched to mopar performance ones haven't had any problems(knock on wood).
Old Sep 10, 2008 | 12:03 PM
spec1sef's Avatar
spec1sef
Default Its fixed. It was the plug gaps
Took the plugs out and regaped them little tighter with the guage.
The hesitation is completely gone.
