2001 2.0 SOHC vs 1997
Old Sep 10, 2008 | 08:30 PM
smallblockfreak's Avatar
smallblockfreak
A neon won't bend the valves unless it's above 2,000 rpms. Tear the motor down your gonna have to anyways.
Old Sep 10, 2008 | 08:47 PM
bone33's Avatar
bone33
Originally Posted by briandownunda
are the heads the same for the 2 models ?
the whole engine is the same, its the sensors that might be the difference. you are going to have to look real good and make sure all the fittings and sensors will hook up in the right places with the right connectors. the PCM is the same on both these model years. while you are at it change the timing belt, tensioner and water pump.
Old Sep 10, 2008 | 08:57 PM
bone33's Avatar
bone33
edit *nevermind*
Old Sep 12, 2008 | 08:29 AM
briandownunda's Avatar
briandownunda
Is there any way to tell if there has been damage, bent valves etc. without removing the head ?
Thanks !
Old Sep 12, 2008 | 10:58 AM
smallblockfreak
do a compression test on it.
Old Sep 12, 2008 | 12:48 PM
briandownunda
so, put a new timing belt on it & do a quick compression test prior to tearing it down ?
