Drain Oil for Oil Change?
Old Sep 14, 2008 | 03:27 PM
JayNYOne's Avatar
JayNYOne
Angry Drain Oil for Oil Change?
Okay, I'm starting to feel like a moron. I've done Oil Changes on my own car plenty of times, but I'm trying to do one on my friend's 2005 Neon SXT and can't find the damn Oil Drain Plug. I see the filter...don't see the Plug. Can someone give me directions before I lose my damn mind?
Old Sep 14, 2008 | 03:47 PM
JayNYOne's Avatar
JayNYOne
I found it - didn't expect it to be up on the side - now I'm fighting to get the damned thing off.
Old Sep 14, 2008 | 05:52 PM
AnthemBassMan's Avatar
AnthemBassMan
-Just remember, "Lefty loosey, righty tighty!"
L8R,
Matt D.
Old Sep 14, 2008 | 06:13 PM
I own only Dodge's Avatar
I own only Dodge
Just be careful not to strip the head on your plug. I just had to remove my oil pan to get the plug out of mine. Oh and autozone has your replacement $3.99 just incase yu ruin that one getting it out.lol
Old Sep 14, 2008 | 06:20 PM
AnthemBassMan
-Yeah, keep the cresent wrenches and vice grips away from the drain plug. Either use only a 6pt socket or box end wrench.
L8R,
Matt D.
Old Sep 14, 2008 | 08:23 PM
I own only Dodge
yes definatly, and if you plan on changing it in the future it really doesnt need a whole lot more than hand tightening. The rubber seal on it will prevent the seizing like you have now, If you overtighten it again its just gonna stick when you crush the seal and the plug makes contact with aluminum pan.
Old Sep 14, 2008 | 10:53 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
yes, putting the drain plug back in is not a strength contest!!! i had to replace mine after letting stiffy-lube change mine a while back, damn near stripped the thing gettin it back off, new one was only a few bucks though.
Old Sep 14, 2008 | 11:13 PM
djmagic's Avatar
djmagic
also dealer has them for like 8 bucks, same size and all
Old Sep 15, 2008 | 01:08 AM
N30N's Avatar
N30N
lol.i onlyowndodge man i knew you would throw that out there.but yea they can be tricky to find....
Old Sep 15, 2008 | 03:14 AM
Exubus's Avatar
Exubus
I only ever went to an oil change place twice for any of my vehicles... both times, the douche-nozzles rounded off the hex on my drain plug with what appeared to be the teeth of channel-locks. No one has touched my vehicles since then, except me.
