Port matching throttle body with intake manifold
Old Oct 17, 2008 | 07:24 PM
cody223's Avatar
cody223
Default Port matching throttle body with intake manifold
Hi, I have a 2000 dodge neon and I just bought a 55mm throttle body. I was going to install it last weekend however, I was told to port-match the throttle body with the intake manifold to get better performance. What does this mean and how is this done?
If someone could reply back i'd greatly appreciate it.
Thanks,
Cody
Old Oct 18, 2008 | 02:19 AM
contagious19's Avatar
contagious19
damn a 55mm is da best opening u can get for da neon, better dan 60mm. but i believe wat they are telling is to port da side da goes to da intake manifold not da intake
Old Oct 18, 2008 | 07:06 AM
cody223's Avatar
cody223
thanks contagious19 I appreciate your reply. I also have another question though on this other forum i'm not sure if it's just the drivers accerlerating too hard or if it's an actual problem. However, The other forum stated that with a 55mm throttle body it's hard to maintain a certain speed and that on take off it's very hard not to spin the tires and the car is very jumpy, since the throttle response is so quick. is this true?
Old Oct 20, 2008 | 01:41 AM
contagious19
well i spin my tires wit 17" rims wit my stock throttle body. most of da reason is da engine movement, if u put some motor mount inserts it would reduce wheel hop and u well get better throttle response
Old Oct 20, 2008 | 10:08 AM
mjs182004's Avatar
mjs182004
wouldn't a 60mm TB be better than a 55mm TB?
Old Oct 20, 2008 | 01:28 PM
srtgtr34's Avatar
srtgtr34
Yes only if you have forced induction or have some head work, If you don't its more of a drawback instead of a gain.
Old Oct 22, 2008 | 02:14 AM
contagious19
yea 60mm is bigger but you will need a lot of supportin mods. i read many threads about throttle bodies and 55mm is wats recomemnded but no one makes it. u gotta make ur own one or have someone make one
