Srt4 rims on neon 2001
Old Oct 23, 2008 | 03:42 PM
vandit's Avatar
vandit
Exclamation Srt4 rims on neon 2001
Hi.
What can i do to make the SRT4 rims with 205/50R17/XL 93Y tires fits on 2001 neon??? cause they do not.. (shocks)
Old Oct 23, 2008 | 05:12 PM
contagious19's Avatar
contagious19
u need to run 205/40. 50 profile is too big for our stock struts or u can get srt struts and da 205/50 would fit fine but u need a 40 series tires over 50
Old Oct 23, 2008 | 06:51 PM
srtgtr34's Avatar
srtgtr34
Contagious pretty much covered it but I would like to add that you can run a 45 series tire (205/45/17) with stock suspension as long as you don't turn the wheel all the way alot of times.
Old Oct 23, 2008 | 07:36 PM
vandit's Avatar
vandit
so then if i get the SRT struts, they fits in neon 01?
Doing that the SRT4 rims with 205/50R17/XL 93Y tires will fit ok in the 01 neon?
Thxs for your help my friends
Old Oct 23, 2008 | 07:47 PM
srtgtr34's Avatar
srtgtr34
Correct. Also if you buy the srt struts, you can add a sway bar because they have the sway bar mount and most likely your curent struts don't.
Old Oct 23, 2008 | 08:21 PM
Adionik's Avatar
Adionik
Put a 5mm spacer, it'll allow it to clear
Old Oct 24, 2008 | 02:08 AM
contagious19
yeap, wit srt struts u can run a 50 series tires, (srt struts will bolt up to ur se without problems). w/o srt struts u need 40 series tires mayb 45
