Transmission Cooler (2000 neon)
Old Feb 8, 2005 | 12:05 AM
laxdudeee's Avatar
laxdudeee
Default Transmission Cooler (2000 neon)
Hey you guys new to this board, my dealings are mostly with eclipses and talons but I'm deviating for a friend in trouble. He recently lost all of his tranny fluid and the tranny started to slip (auto) and lost all power. Poured fluid in it, and it poured right back out. He recently got into a minor accident on his front passenger side. I believe that he damaged the tranny cooler causing a hairline crack that split open after time, does this sound feisable? A stock 2k neon has a tranny cooler on that side if I am not mistaken, right?
Summary:
1) is there a tranny cooler on the front passenger side
2) where can I find a cheap but effective STOCK replacement?
3) are all of the lines metal leading to and from the tranny?
Thanks a lot you guys for helping out a fellow car enthusiast!
-Eric Dombrowski
Old Feb 8, 2005 | 01:51 AM
y2neones's Avatar
y2neones
Default RE: Transmission Cooler (2000 neon)
im not sure where it is... but if that ends up being the problem, id go to a junkyard for the replacement
