2.0l Motor mounts
I was under my car yesterday doing a tranny flush with new filter and whatnot, decided to take a look around and apart from the grease nipples on the bottom of the spindles being broken off All my motor mounts are completely shot. I mean the rubber is broken all the way around. My cars been vibrating alot more then usual and it's making my interior like slowely loosen and make noises.
My question is, I found those urethane inserts on Ebay, but they are all for SRT 4's or the first gen neon. Are the SRT's mounts the same? (Hole diameter, both on mount and bolt) and will I be able to just hammer the old ones out or will I need to use the press at work afterhours to push the old ones out and put the new ones in?
Thanks in Advance...
Oh, and should I go urethane? Or OEM Rubber? Will Urethane be more solid then rubber and make the car vibrate even more?
