Change to High Mileage Oil, do it or not?
Old Oct 21, 2008 | 11:32 PM
Chrysler_Neon's Avatar
Chrysler_Neon
Default Change to High Mileage Oil, do it or not?
My 00' Neon have 80,000 miles and the engine is consuming oil (1/4 every 1,500 miles) I should change to High Mileage Oil? What is the best brand?
Thanx for your help!!!!
Old Oct 22, 2008 | 01:56 AM
contagious19's Avatar
contagious19
i didnt go highmilage untill 100k
Old Oct 22, 2008 | 02:12 AM
darthroush's Avatar
darthroush
Section Moderator
I grabbed the Valvoline High Mileage because:
1. It is available in a 5 qt. jug in 5W-30.
2. It is a semi-syn blend (just an added bonus).
3. It is about the same price or cheaper than all of the regular oils.
Either way, whatever brand you pick, stick with it!
Old Oct 22, 2008 | 09:27 AM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Valvoline Max Life is real good. Ive used it in my other car. You can start using it at 75k. So your starting at the right time. Here is there site so you can see the difference between there Max Life Synthetic and there Max Life.
http://www.valvoline.com/pages/produ...gory.asp?cid=9
Old Oct 22, 2008 | 04:43 PM
bone33's Avatar
bone33
loosing 1/2 quart every 3000 miles is pretty normal. high mileage oil is your call, but ive had alot of high mileage (over 150k) cars in my life and i never used anything special in them. i think its some marketing BS anyway. oil is oil.
Old Oct 23, 2008 | 08:52 AM
KARR's Avatar
KARR
For me with my other car. The high mile oils helped with the knocking sound and made the car feel smoother to start and drive. Thats why I used it.
Old Oct 23, 2008 | 10:36 AM
mannyfresh18's Avatar
mannyfresh18
so what brand of oil do you guys recommend.
rite now im running 10w 30 pennzoil.thats what the shop put in it last time but i need to do an oil change before it gets too cold and i was going to do it myself this weekend.
is pennzoil any good ? and is that the rite weight for being at 67000 miles.
well sorry if i sound stupid but i dont really know much about oils and diff types.
can someone pin point me in the rite direction of which oil to use next or should i stick with pennzoil ? ?
Old Oct 23, 2008 | 11:54 AM
darthroush's Avatar
darthroush
Section Moderator
If your car is running fine with it, you can stay with it. The way to how well an oil cleans of course is by the API rating on the back. I think my car had 10W30 in it when I bought it, but I switched to the recommended (preferred I guess) 5W30. For regular oil, almost any brand that has an API rating for your year or newer will be fine. I just happen to like Valvoline, Castrol, and even the SuperTech oil (relabled name brand oil) when it comes to plain dino oil.
No matter what you choose, keep staying with that brand oil. Switching brands of oils constantly isn't good.
Old Oct 24, 2008 | 04:34 AM
djmagic's Avatar
djmagic
I don't like regular penzoil cause it leaves that gunk on the bottom of the oil cap. And I figure since it is there its probally in the engine too. I do 10W30 since it is hot as heck here. I think 5W30 or 5W20 is reccomended up north. I agree with darthroush, don't switch back and forth, choose one and stick to it. My car origionally had valvoline and when I got it, I switched to castrol. Any manny, please tell me you aren't taking your car to walmart.
Old Oct 24, 2008 | 07:57 AM
mannyfresh18
lol no i dont take my car to a walmart why ??
i took it to best one here in richmond.but i dont like taking it too shops cause i have to take my front off to get be able to get it up the ramps. but ill just stick with the 10w 30 pennzoil.
