problems with 2005 dodge neon SXT
Old Nov 16, 2008 | 03:51 PM
drftz31's Avatar
drftz31
i have had this problem with my car also, it was my camshaft sensor and knock sensor, the cam shaft sensor is really easy to fix, it the square, with circle on it, i think all the bolts are size 10mm. it should atke about ten minute to replace, and your fine.
Old Jan 16, 2009 | 12:00 AM
usmc_escobar's Avatar
usmc_escobar
Unhappy Driver side rear door won't open?????
Yesterday I tried to open the door and it wouln't open. I have the child safty on and thought it was that but it's not. It's the only one of the doors that won't open. Don't know if this has anything to do with code P0038. Any info will help.
Old Jan 16, 2009 | 01:43 AM
darthroush's Avatar
darthroush
Section Moderator
Won't open from the inside or outside? I'm guessing this is a back door? No, a CEL won't cause one door not to open.
Old Mar 28, 2011 | 02:55 PM
Confused101's Avatar
Confused101
I have a 2005 neon sxt 2.0. Wont start or turn over with key. Changed the PCM, Ignition switch, battery, starter. All are new, but still won't turn over with key. Ran a jumper switch to turn over the starter and turned key to on position but still will not start. Checked starter relay and that is ok. All fuses are good. Any sugestions????
Old Mar 28, 2011 | 03:12 PM
showsxt's Avatar
showsxt
Try alternator , plugs wires and coil all that might help start your sxt. timing belt might need to be changed also.
Old Sep 27, 2011 | 11:54 AM
Lost4202010's Avatar
Lost4202010
Default only mopar
Originally Posted by mjs182004
I would replace the cam sensor. and you also should not have to pump the gas to get it to start. that has no affect on whether or not the car won't start. you only have to do that on carbureted cars.
'true to some extent but fuel injected cars also use air suction throttle. the more air let in the more fuel it mixes with it. so pumping wont help as much as depressing the pedal all together will. just my two cence.
and as far as the cam position sensor goes.. good luck. alot of people have problems with this car and sensor. ide recommend only replacing with mopars parts too. the after market sensors would go bad on me after a month or two.
Old May 3, 2012 | 07:55 PM
Matt Workman's Avatar
Matt Workman
I have a 2005 dodge neon and the transmission light came on and the car get stuck in 1st and sometimes 2nd gear.Sometimes it goes thru all the gears. Had the computer replaced and didnt help. Dont think its the transmission cause it dont do it all the time. Need some advice.
