largest?
Old Feb 13, 2005 | 11:19 PM
jonbonazza's Avatar
jonbonazza
Default largest?
what is the largest size engine i could fit into an 03 SXT?
Old Feb 14, 2005 | 12:04 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: largest?
However big your wallet and however much time you have. But to be more realistic and reasonable, you should be able to drop a 2.4 in there without too many problems as long as you have everything.
Old Feb 14, 2005 | 01:09 AM
lonasindi's Avatar
lonasindi
displacement isn't the end all anymore, go with the srt engine if you're looking for power. it's a relatively easy fit, I've heard the mounts are all the same
Old Feb 14, 2005 | 01:23 AM
jonbonazza's Avatar
jonbonazza
i was thinkin of dropping a 2.4 DOHC and getting a custom turbo
and go from there with the internals like the cams and stuff
Old Feb 14, 2005 | 02:03 AM
GroundControl's Avatar
GroundControl
you would probley need a new computer. like one from the srt im assuming.
Old Feb 14, 2005 | 02:12 AM
LowSlowNeon
If you were going to drop a 2.4 in their, just go with the SRT4 motor. Get the wiring harness, tranny, axles, everything. It would be far easier to work with then taking a 2.4L NA motor and turboing it. A lot of your work would already be done with the SRT4 motor.
Old Feb 14, 2005 | 03:11 AM
casper's Avatar
casper
I am gonna agree with the SRT-4 motor, thats probally the easiest and best. But you can do anything, throw a chevy 350 in and make it rear wheel drive, anything is possible.
Old Feb 14, 2005 | 09:41 AM
FLC's Avatar
FLC
or just go get a dodge srt4 and save yourself the trouble.
Old Feb 14, 2005 | 11:00 AM
chud298's Avatar
chud298
I'd have to agree with the SRT-4 engine. I was even thinking about dropping that in my 1998 neon r/t. All the munts are the same on mine too
Old Feb 14, 2005 | 08:31 PM
tom's Avatar
tom
i heard that the chassis is different with the srt4 compared to the se and sxt, because i guess if you drop a 2.4 in a se or sxt chassis it will eventually twist it. [sm=nerd.gif]
