Ignition Trouble???? Please Help!!!
Old Dec 14, 2008 | 03:11 PM
hertzog1284's Avatar
hertzog1284
Default Ignition Trouble???? Please Help!!!
Ok, I have a 2003 Dodge Neon with a Hahn Racecraft stage 2 turbo kit on it. I just got finished installing the Crane Cam 0012 in the car. And when I went to start the car, it sputtered for a second and revved up to 6,000 rpm before I could shut the car off. And the car does not throttle down. So I attempted to restart the car and same results.
The car gave me two codes so far:
P0351- Ignition coil #1 peak primary circuit current not achieved with maximum dwell time
P0352- Ignition coil #2 peak primary circuit current not achieved with maximum dwell time.
Can someone please help, I have a Haynes manual, and its no help.
Old Dec 14, 2008 | 08:34 PM
hertzog1284
Ok, I got the codes to erase. And I replaced the Throttle Position Sensor, and still the car wants to run away. As soon as I start it, the car revs up?
Old Dec 15, 2008 | 01:02 PM
tooslow's Avatar
tooslow
make sure you don't have any vacuum leaks It has too be a big leak also pull the boost pipe of the t/b and make sure it closes all the way
Old Dec 24, 2008 | 09:45 PM
mcfisher1980's Avatar
mcfisher1980
sounds like a vacuum leak to me
