squealin' neon
Old Dec 21, 2008 | 02:40 AM
04neonrtguy's Avatar
04neonrtguy
Default squealin' neon
So i replaced my timing belt, and both serpentine belts at 95k (water pump and timing belt tensioner as well). I noticed a very small squealing noise. Now, the car has 105k and the squealing starts when i start the engine, goes for about 10 or 15 seconds and stops. The car drives fine and when i reach my destination and stop, car still running, it does a real high pitch squealing noise and goes for however long it wants to. Someone said it might be a pulley, guy at the car shop said it might be my a/c compressor, because i have it on defrost when it does it really bad. I looked and its gonna be fun gettin to the a/c compressor so i don't want to have to do it and have it not be whats really wrong with it. I have not been on this site in a while now, and plan to start checkin it out more often. Any ideas would be greatly appreciated
Old Dec 21, 2008 | 06:59 PM
bigduvall's Avatar
bigduvall
Did you check your brake pads?
Old Dec 28, 2008 | 03:15 AM
04neonrtguy
haha. it wouldnt do it when the car starts up. i know this much about cars. thanks for trying to help tho, i seen a whole lot of views and nobody could put their 2 cents in.
Old Dec 28, 2008 | 02:42 PM
darthroush's Avatar
darthroush
Section Moderator
How would the brake pads make a continuous loud squealing when the car is stopped
Old Dec 28, 2008 | 02:47 PM
OneBadKota's Avatar
OneBadKota
Best bet would be to take some WD-40 and spray each pulley as it runs. Do you live in a cold weather climate? I've had my belt squeal sometimes on vehicles when it was cold out. For a short period.
.02
Old Dec 28, 2008 | 11:04 PM
mcfisher1980's Avatar
mcfisher1980
check your belt tensioner on your serpentine belt and check the alternator belt as well. that might need to be tightened up a little. get some belt dressing, not wd40 and spray it on your pullys. that may resolve your issue
