gauges
Old 01-05-2009 | 12:40 AM
mcfisher1980's Avatar
mcfisher1980
Default gauges
anyone know if theres a way to change out the stock instrument panel for a different design or at least change the color of the bulb. i know of some sites that sell them for other vehicles, but havent seen any for the neons.
Old 01-05-2009 | 02:47 PM
darthroush's Avatar
darthroush
Section Moderator
There are a couple of places to order LED kits, but it seems if you order a color other than white, you have hot spots and dull spots. I have seen if you get white LEDs, it turns them a nice blue without the above problems. ByVamp and Autolumination have kits.
I just wish there was some sort of gauge overlay, lol.
Old 01-05-2009 | 02:57 PM
j_son600's Avatar
j_son600
Here you are Speedhut, you can customize them any way you want.
Old 01-05-2009 | 03:05 PM
srtgtr34's Avatar
srtgtr34
If you need some help throw me a pm, I will tell you everything you need to know about changing the led's out. From past experience, I would not buy from vamp again. I only order my leds from superbrightleds and autolumination.
Old 01-05-2009 | 04:36 PM
mcfisher1980
for right now im just trying for something other than green or a complete gauge replacement. but thanks for the links, i will check them out.
Old 01-06-2009 | 02:42 AM
djmagic's Avatar
djmagic
I have the byvamp kit and there is some spots that are brighter than others, still like the looks though.
Old 01-06-2009 | 03:09 AM
darthroush's Avatar
darthroush
Section Moderator
Forgot about that place, thanks!
If you type it all up, would you mind sending a copy my way?
Trending Topics
Old 01-06-2009 | 09:52 AM
bad venge's Avatar
bad venge
Section Moderator
http://www.importintelligence.com/index.html
He makes gauge faces as well ...
Also to brighten up the clusters get his intelliglo needles ///
Here's what mine looks like at night :
Old 01-06-2009 | 12:07 PM
darthroush's Avatar
darthroush
Section Moderator
Doesn't have any second gen Neon gauges, but I am curious about the needle kit. You just use the factory red needles and it makes them glow like that, or does it come with new clear ones?
Old 01-06-2009 | 12:11 PM
bad venge's Avatar
bad venge
Section Moderator
http://www.importintelligence.com/FM...dex.html&-Edit
The kit has mini LED's that go under the center ring , I stripped my "red" paint from the needles and painted the underside white with a 1/4" red tip the blue really shows up
Also If those aren't the gauges you have , Matt WILL custom make a set ... I sent my cluster into him to make the first one for the venges
Quick Reply: gauges
