trying to resolve P0303 error on '01 Neon SE with auto tranny
Old Apr 18, 2009 | 11:22 PM
Forge04's Avatar
Forge04
Default Same problem on Cyl 2
I'm having the exact same problem on cyl 2. replaced wires, plugs, and looked at the injector, it looked fine. Ohm test on the injector reads 13.0-14.0 on all injectors. Voltage appears to be the same on all connectors going to the injectors. Tonight after over a month of sitting it fired right up, and took off with out a hiccup. It ran all night with no issues, until we left McDonalds and on ignition the hiccup was there. Then in the middle of driving, it smoothed out. I don't have the money to shell on a coil pack if that isn't the problem, but if it's the burnt valve how does one go about fixing that?
Old Apr 19, 2009 | 03:01 AM
darthroush's Avatar
darthroush
Section Moderator
Replace it.
Old Jan 15, 2012 | 07:11 PM
PWILLIE87's Avatar
PWILLIE87
New Member
You sir are a life saver!!!! Thanks
