gauge cluster
Old Feb 20, 2009 | 12:06 PM
THOR20's Avatar
THOR20
Default gauge cluster
i have an 05 neon with an automatic transmission the gauge cluster has no tach is it possible to swap this for one that does and will it simply plug diretly in? also is it possible to put a manual shift **** on instead of the automatic one because i cannot find a led automatic **** anywhere
Old Feb 20, 2009 | 12:15 PM
one_disturbed_person's Avatar
Not sure about the shift ****....
The cluster plugs directly in and the only thing you will lose is the mileage. I just installed the 2004 cluster in my 2001 SE because it didn't include a tach. I got my cluster off ebay for $40 shipped. Check them out. I had the question a long time ago about whether or not the tach was already wired into my factory harness. I found out that they are for all Dodge vehicles manufactured after 1980.
Daniel
Old Feb 20, 2009 | 02:57 PM
darthroush's Avatar
darthroush
Section Moderator
If you put a manual shift **** onto your automatic, how would you shift it? You have to have the button to unlock the shifter. If you really need an LED shift ****, I'm sure you can find one on eBay at the least.
Old Feb 20, 2009 | 10:26 PM
Pablodragon's Avatar
Pablodragon
+1 on the guage cluster ...I also replaced my SE non-tach cluster with one from an SXT.. which also changed it from the black gauge faces to the white gauge faces, as well as gaining the tach...got mine from e-bay also for right around the same price.
On the auto shift ****, I can relate.... there is NOT alot of auto replacements to be found on e-bay...possibly even NONE at most times...there are TONS of manual replacement *****. I had also wanted to change mine to something non-stock-y, but gave up. I did read here, or somewhere, that u can use a non-button auto ****, and to switch positions, u just push down...supposedly, that's all the button does.
I'm not a big fan of mounting something that LOOKS like a manual shift.... what do u do, PRETEND to shift when yer at a stoplight or driving?... seems to me the same as mounting SRT-4 badges on yer trunk when u don't even have an SRT-4 or even a turbo, ..and people rag on that to no end
Old Feb 20, 2009 | 10:39 PM
THOR20's Avatar
THOR20
so far these seem to be my only options which one do you think would look the best..
Attached Thumbnails gauge cluster-shiftknob.gif   gauge cluster-3197494154_c85fff6a6c_o.jpg   gauge cluster-pd_blue_cf_shift_knob.jpg   gauge cluster-toutk177blue.jpg
Old Feb 20, 2009 | 11:34 PM
OhNo2.0's Avatar
OhNo2.0
Depends what color your car is...and if the **** will actually work.
Old Feb 21, 2009 | 08:39 AM
THOR20's Avatar
THOR20
right now the car is white and the interior is going to be blue and black. and eventually i am going to get the car painted black with some sort of blue tribal design or something on it
Old Feb 21, 2009 | 08:53 AM
likeke34's Avatar
likeke34
[edit]
my bad, they're not led's... ignore this post lol
