Motor Mount Trouble PLEASE HELP! :D
Old Feb 22, 2009 | 10:47 PM
nappypalms's Avatar
nappypalms
Exclamation Motor Mount Trouble PLEASE HELP! :D
I am in the process of changing out my water pump and timing belt.
I got those changed out but I can't seem to get the motor mount of the passenger side to line up properly.
Do ya'll have any tips on getting this to line up? I have tried everything that I can think of.
Thanks in advance guys.
Old Feb 23, 2009 | 01:31 AM
contagious19's Avatar
contagious19
i would just raise and lower the engine to make it line up
Old Feb 23, 2009 | 08:36 AM
nappypalms's Avatar
nappypalms
I have tried that but I can't get it to line up just right.
Is there anything else you could recommend?
Thanks
Old Feb 23, 2009 | 01:26 PM
contagious19
try unbolting the motor mount from the frame and bolt it on to the engine. not too tight so u can move it around and try to bolt it to the frame
Old Feb 23, 2009 | 02:06 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
the lower motor mounts are notched, so if u loosen the one up going to the car, u will get some play in it... then try to move the motor and it should line up.
Old Mar 4, 2009 | 03:27 AM
neonftw87's Avatar
neonftw87
make sure the rubber bushing is not coming down and blocking the hole up for the bolt to come thru, and just like contagious said, carefully raise and lower till you get the mount flush, use a trouble light just to be sure, it cant be that hard bro... good luck
Old Mar 4, 2009 | 04:01 PM
darthroush's Avatar
darthroush
Section Moderator
Which mount? There is a certain spot that Dodge recommends in the shop manuals to jack the engine up to help achieve proper alignment. It is basically on the front of the oil pan area so you can kind of rock the engine back and forth by raising/lowering to line it up-.
Old Mar 6, 2009 | 10:13 AM
blueproracer's Avatar
blueproracer
i had the same prob. the motor has to be rotated backwards. almost like the top of the motor is going into the fire wall like. and drop below the mount and jack up into position rather than lower into position.
