2000 dodge neon The car will not start still!!!
Old Mar 14, 2009 | 02:09 AM
darthroush's Avatar
darthroush
Section Moderator
If you have a CEL on, the code would be most helpful.
Old Mar 14, 2009 | 04:17 PM
rsalgado29's Avatar
rsalgado29
I took it out for a drive and it doesnt let me pass 2400 rpm on any gear it feels like its about to turn off like if I was down shifting. what's a cel and the code? I don't get it? am paranoid it's my ride to work I have no other vehicles not even a bike. well am f..... if I don't get it fixt.
Old Mar 14, 2009 | 04:54 PM
rsalgado29's Avatar
rsalgado29
Ok I got the codes P0325, P0340, P0325PD, P0340PD.
Old Mar 15, 2009 | 02:51 AM
darthroush's Avatar
darthroush
Section Moderator
Symptom:
P0325-KNOCK SENSOR #1 CIRCUIT
When Monitored and Set Condition:
When Monitored: With the ignition on and the engine running.
Set Condition: The Knock Sensor circuit voltage falls below a minimum value. The
minimum value is from a look-up table internal to the PCM and is based on engine rpm.
DTC also sets if sensor output is approx 5.0 volts and the engine is running within idle
range. One Trip Fault.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
KNOCK SENSOR CIRCUIT SHORTED TO VOLTAGE
KNOCK SENSOR CIRCUIT SHORTED TO GROUND
(K42) KS SIGNAL CIRCUIT OPEN
(K42) KS SIGNAL CIRCUIT SHORTED TO (K45) KS RETURN CIRCUIT
(K45) KS RETURN CIRCUIT OPEN
Old Mar 15, 2009 | 02:52 AM
darthroush's Avatar
darthroush
Section Moderator
Symptom:
P0340-CAMSHAFT POSITION SENSOR CIRCUIT
When Monitored: Engine cranking/running. Battery voltage greater than 10 volts.
Set Condition: At least 5 seconds or 2.5 engine revolutions have elapsed with crankshaft
position sensor signals present but no camshaft position sensor signal. One Trip Fault.
POSSIBLE CAUSES
INTERMITTENT CRANKSHAFT POSITION SENSOR SIGNAL
INTERMITTENT CAMSHAFT POSITION SENSOR SIGNAL
(K7) 5 VOLT SUPPLY CIRCUIT SHORTED TO GROUND
(K7) 5 VOLT SUPPLY CIRCUIT OPEN
(K7) 5 VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
(K44) CMP SIGNAL CIRCUIT SHORTED GROUND
(K44) CMP SIGNAL CIRCUIT OPEN
(K44) CMP SIGNAL CIRCUIT SHORTED TO VOLTAGE
(K44) CMP SIGNAL SHORTED TO (K7) 5 VOLT SUPPLY CIRCUIT
(K4) SENSOR GROUND CIRCUIT OPEN
PCM - (K7) 5 VOLT SUPPLY
PCM - (K44) CMP SIGNAL
TEST ACTION
Old Mar 15, 2009 | 02:53 AM
darthroush's Avatar
darthroush
Section Moderator
Looks like you need some new sensors.
Old Mar 15, 2009 | 11:51 PM
rsalgado29's Avatar
rsalgado29
Naa I got it I messs with the udp to hold the flywheel so I think It might be the timeing belt, because I didn't even touch the sensors not even pull on the cables am sure thats what it is let me now what you think?
Old Mar 16, 2009 | 12:54 AM
darthroush's Avatar
darthroush
Section Moderator
Well, you only get the codes if something with them is wrong. You don't have to mess with sensors for them to go bad. Look at the causes of the codes. If your timing was off, you'd have a bigger problem than a CEL.
Old Mar 16, 2009 | 10:48 PM
rsalgado29's Avatar
rsalgado29
ok it's not the timeing and I clean the sensors one code disapear the PO325 but
P0340-CAMSHAFT POSITION SENSOR CIRCUIT still there I repleace it with a new one and it still there mi car takes a long time to start then when I hit the gas it won't let me pass 2400rpm wtf could it be I siriusly feel like sh++ and not only that am broke too no money
Old Mar 16, 2009 | 10:51 PM
rsalgado29's Avatar
rsalgado29
do you think it might be a ground cable?
