SRT plug wires
Old Feb 27, 2005 | 02:29 PM
LowSlowNeon's Avatar
LowSlowNeon
Default SRT plug wires
In case anyone is wondering.....they do work on the regular neon. I got some 9mm plug wires on a group buy from srtforums. Well I put them on last night and car idles fine, runs fine, everything. In fact, my car used to hesitate at times when starting out in gear before i switched wires. It hasn't done that yet and seems like it actually runs smoother with the new wires. I'll have to take a look at my old wires to see if maybe one of them was burned, but I didn't look too close last night cause I changed them in the dark. I post a pic up later today cause they're yellow wires, to match the rest of my scheme with the car.
Old Feb 27, 2005 | 11:53 PM
LowSlowNeon
Default RE: SRT plug wires
Heres my nifty color coordinated wires.
[IMG]local://upfiles/1628/799F93A3CAC244F88F33D430C7C59D66.jpg[/IMG]
Old Feb 28, 2005 | 01:26 AM
techmanbd's Avatar
techmanbd
Thatg is cool. Good to hear. I may get them first because of that hesitation. I doubt your wires are burned, because mine has been doing that hesitation since I got it. And talked to someone where I use to work that has an 03 and had the same problem.
Old Feb 28, 2005 | 02:06 AM
LowSlowNeon
Mine hasn't always done it though. Just recently its been doing it semi-often. Its kind of annoying because it goes and then it bogs for a second, then goes (only does it in first gear). I thought it could just be all the cold weather and such and the computer adjusting things, but I'm beginning to think that wasn't it. The only reason I switched my wires was because I found yellow ones. Anyways, I have a pic of my stock wires vs my new wires. Look at how much bigger the wire on the new ones is. Since I have replaced, no hesitation, idles like normal, and goes as good if not better under full load.
[IMG]local://upfiles/1628/F9CB8C2B40B8457BA03A7458D83EBE8D.jpg[/IMG]
[IMG]local://upfiles/1628/1DDB55F3A4994B57BBD2CA28E148F3E5.jpg[/IMG]
Old Feb 28, 2005 | 02:30 AM
techmanbd's Avatar
techmanbd
Cool, I am hoping to start fixing up my neon now with the new job, had a majr increase in pay so hopefully can start putting into it/
Old Mar 1, 2005 | 11:42 PM
duelsxt's Avatar
duelsxt
Looks Good. You should clean up your enginge though. Looks kind of dirty.
Old Mar 2, 2005 | 12:15 AM
LowSlowNeon
Dude....you obviously don't live in michigan or anyplace where it rains or snows. There is no point to me cleaning my engine bay unless my car is going in a show because it will just get dirty again....but thanks for the comment. I already knew my engine bay was dirty, I wasn't trying to win a clean engine bay award. I'll clean it up in the summer when will actually stay clean for awhile.
