Engine/tranny swap
Old Mar 1, 2009 | 07:31 PM
OhNo2.0's Avatar
OhNo2.0
Default Engine/tranny swap
For some reason it says in the haynes manual that the car gets lifted over the engine? So the engine comes out the bottom not the top. I've got everything taken off my engine(Harness, lines, etc) and it looks really tight in there...is it possible to lift it out the top? Anyone done this before on a neon?
Old Mar 1, 2009 | 07:49 PM
NeonOn19s's Avatar
NeonOn19s
all my buddies that have done a motor / tranny swap done it from the bottom. It will be a lot easier.
Old Mar 1, 2009 | 08:16 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
i did mine out the top... it was not to bad if u have everything off the block.... make sure it is tipped at an angle, tranny lower, and pull the hood off.. and it comes right out.... going back in is a trick however
Old Mar 2, 2009 | 09:38 AM
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
I'd go out of the bottom.
Old Mar 2, 2009 | 12:22 PM
dtjackten's Avatar
dtjackten
prolly next time i pull it i will do it out the bottom... hard with no lift though... getting the car up that high...
Old Mar 2, 2009 | 12:41 PM
darthroush's Avatar
darthroush
Section Moderator
That's what a forklift is for, sure makes changing the brakes easier anyways!
Old Mar 2, 2009 | 12:59 PM
NeonOn19s's Avatar
NeonOn19s
nice.. that will work
Old Mar 2, 2009 | 01:37 PM
dtjackten's Avatar
dtjackten
LOL, that is great!!!
Old Mar 2, 2009 | 01:52 PM
tooslow's Avatar
tooslow
I have taken out the motor out the top many times you just got angle it right the tranny has too almost be pointing straight down. too the bracket for the battery tray
Old Mar 2, 2009 | 04:00 PM
dtjackten's Avatar
dtjackten
i just pulled the battery tray out.. came out fine...
