2 Questions
Old Mar 22, 2009 | 12:16 PM
irishking's Avatar
irishking
Question 2 Questions
I have 2 questions hopefully someone can help. Im looking to take out my headliner. does anyone know how I can do so or how hard it is to take out.
question 2. I have a sun roof and I can open it. When i go to close it, it seems like it is stuck. I dont know if that is my motor going bad or does somethink it might be off track.
Old Mar 22, 2009 | 12:28 PM
N3ON's Avatar
N3ON
if i was you i'd check your motor on the sunroof.
do you have oh S*** handles???
Old Mar 22, 2009 | 12:31 PM
irishking's Avatar
irishking
lol oh s*** handles.. I thought i was the only one that called them that. and yes i have 4
Old Mar 22, 2009 | 12:37 PM
N3ON's Avatar
N3ON
ha ha ha no dude i call em that too but i dont have em
i have no idea how to take the headliner off but im sure someone does.
Old Mar 22, 2009 | 12:40 PM
irishking's Avatar
irishking
im guessing i have 2 take off the headliner 2 get to the sunroof motor right
Old Mar 22, 2009 | 12:48 PM
N3ON's Avatar
N3ON
you know i've never had a sunroof but i want one though.here you go
SUNROOF MOTOR REPLACEMENT
Removal Instructions
Step 1 Before removing the motor for the sunroof, the sunroof must be fully opened in the tilt position and then closed, so the mechanics and electronics will synchronise when installing the new motor. By removing the side cover, you can check to see the position of the mechanism. The slide shaft should be between the marks 1 & 2 on both sides. If the sunroof motor is malfunctioning, the sunroof can be operated manually using a screwdriver.
Step 2 Remove the headliner.
Step 3 When releasing the locking mechanism on the connector be careful not to damage the connector. Pull the the two halves straight apart so you avoid bending the pins.
Step 4 Disconnect the connector from the sunroof motor.
Step 5 Remove the motor. Installation Instructions
Step 6 Connect the connector to the sunroof motor.
Step 7 The following procedures must be done before installing the new motor. Push the switch up so the motor will operate as though it is going into the tilt/vent function and then release the switch. Press the switch up again but this time hold for about 3 seconds. Using your thumb, press the drive wheel at the same time you are engaging it in the close function by pushing the switch forward.
Step 8 Install the motor. You may have to calibrate the control module, Torque to 2 ft lbs.
Step 9 Install the headliner.
Step 10 Check the function of the sunroof and controls!
and yea you'll have to take it off
Old Mar 22, 2009 | 12:52 PM
irishking's Avatar
irishking
shoot...
Old Mar 22, 2009 | 12:55 PM
N3ON's Avatar
N3ON
if you cant do it then i'd take it to someone.the motor shouldn't be that much and labor should be easy.it would probably be easier on ya.
Old Mar 22, 2009 | 01:36 PM
irishking's Avatar
irishking
yeah but i wanna take out the headliner and put in a differnt color to match the car
Old Mar 24, 2009 | 02:39 AM
contagious19's Avatar
contagious19
headliner removal is pretty easy, i put black fabric on mine. just unbolt the **** handles and the visor clips and i believe the visors remove the rear pillars and the rubber seals and just pry the headliner and it should come off
